Zoukei-Mura 1/32 Ho 229
By Benjamin Jessen
Finished up the Horten 229 from Zoukei-Mura.
The build itself was pretty straightforward. Just needs a lot of planning ahead and dry fitting so you don't forget that one part in the process.
To save some time I added the Quinta set for the instrument panel.
Biggest issue is the clear fuselage parts. They are just difficult to work with. Hard to see if things are aligned and its needs a lot of primer to not be transparent. I still have a few panels here and there I wished were better, but hopefully the paintwork distracts from it.
I decided on a "what if" scheme from the video game World of Warplanes. There is just something about the red wing and dark grey that catches your eye.
To break up all the huge surfaces I used lots of color variation and mottling to add some interest. I'm actually quite pleased with how it turned out!
Weathering was kept minimal - its just more of a personal choice. I feel the really heavy weathering is something I'm not too experienced with, so the look often ends up being too much or just wrong.
I really like the look of these early jets, so happy I finally got around to building one of the kits that have been in my stash for years.... Just waiting on me to get the courage to build it! And the model is absolutely massive! Not easy to take pictures on my small bench!
For more information, the build log can be found in my thread in the Work in Progress forum.
© Benjamin Jessen 2026
This article was published on Friday, November 13 2026; Last modified on Monday, November 16 2026
